steering
Old Nov 4, 2013 | 02:59 PM
ruben24's Avatar
Default steering
Need help on my 06 Cummins I just put all the tie rods New n got an alignment but I can feel a knock on my steering wheel
Old Nov 4, 2013 | 06:07 PM
cerberus60's Avatar
Check for play in the steering box sector shaft, the vertical one.
Old Nov 4, 2013 | 07:24 PM
ruben24's Avatar
How would I check that and i forgot to say that sometimes i feel it on the pedals
Old Nov 4, 2013 | 07:28 PM
cerberus60's Avatar
You need to get a bar on it and see if it moves up and down. The sway bar is a good place to pivot on .
Old Nov 4, 2013 | 09:36 PM
ruben24's Avatar
O ok thanks ill try that
If it has play do I need to buy the whole steering gear box
Old Nov 7, 2013 | 09:07 PM
cerberus60's Avatar
If you can't adjust it out then it is time for a new box.
Old Nov 7, 2013 | 09:16 PM
ruben24's Avatar
Thanks u ill try adjusting it
Old Nov 20, 2013 | 08:53 PM
sinwagon's Avatar
Don't forget to check bushings on your track bar too they will cause the bump in the pedals.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
