Replacing the engine & motor mount interference.
Old Nov 4, 2013 | 11:21 AM
Nevadan's Avatar
Default Replacing the engine & motor mount interference.
I just pulled my KDP "killed" engine this weekend and it was very difficult to get out. In order for the motor mounts to clear the crossmember I had to lift it so high the bell-housing was pushed up pretty hard against the body. I don't see how it will go back in without some change.
I'm thinking about unbolting the motor mounts from the block so I can get the engine low enough to get the transmission shaft and bell-housing properly aligned.
If I bolt the motor mounts to the crossmember and lower the engine into the mounts I'm sure the motor will be low enough to align with the transmission shaft.
I have a manual Getrag transmission.
Any input? Any brilliant ideas?
Old Nov 4, 2013 | 12:27 PM
novapat's Avatar
I was wondering how things went.. I have to install my 12v in my suburban just the way you explained.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Oct 30, 2014 08:10 AM
