ford f-350 lariat 6.0L 2003
Old Nov 3, 2013 | 02:57 PM
Marz Watters's Avatar
Up ford f-350 lariat 6.0L 2003
I was driving home last night and my truck did not give an indication that something was wrong it just quit then it would not start back up, it turns over like it wants to start but it will not start. what could be wrong with it? i appreciate any kind of help and thanks so much!!
Old Nov 3, 2013 | 04:12 PM
Dustindavisusmc's Avatar
With a 6.0 you have a multitude of possible issues, does the oil pressure gauge read any pressure while cranking?... If it does low pressure system should be working... Next is your high pressure oil system... 03 is a good year for 6.0... There are not a lot of things you can do without IDS (diag software). I would imagine that your problem is IPR (injection pressure regulator) or a high pressure oil leak, top of an injector blew off, high pressure oil pump
Rail/manifold leak, or a dead hpop (high pressure oil pump) ... I ride only cummins, but have a couple 6.0s and 7.3s... Without codes or the ability to watch commanded and actual pressures it tough..... If you have something with the ability to command IPR open and Some air you might have chance at back yard diag
Easiest way to tell a true 03 is if the IPC is at right front of engine or underneath turbo (if you don't see a sensor at right front it is an early 6.0)
Old Nov 10, 2013 | 11:22 PM
97cummins's Avatar
makuloco2000
Feb 15, 2015 02:31 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
