93 w250 lift??
Old Oct 27, 2013 | 10:01 AM
logan lacey's Avatar
Default 93 w250 lift??
Can anyone tell me how many inches I can lift my 93 w250 before I have to start changing things???
Old Oct 27, 2013 | 10:19 AM
cougar's Avatar
All it took was an inch and a half to start breaking my front drive shaft on a regular cab 5 speed.
Old Oct 27, 2013 | 04:37 PM
Well thats not what I was wanting to hear can I put a 4 inch lift before i have to change things?
Old Oct 28, 2013 | 06:15 PM
u2slow's Avatar
I'm doing mine in 2" stages so I can address all the side effects as they arise. I have the leafs - not installed yet.
Eventually I'll get Jungle's HD hanger kit, and crossover steering,
Old Oct 29, 2013 | 11:49 AM
cougar's Avatar
The double cardan joint on the front drive shaft has limited travel. Some people grind the stops off of them to get a better angle, but they weren't designed for it. Hi Angle is one aftermarket company that does make a double cardan that has a higher angle.
Old Oct 31, 2013 | 07:02 PM
Thanks that's what I was wanting to know
Old Nov 5, 2013 | 07:40 PM
Ok so when I go to lift the front, the U bolts on the front axle, the one looks like its in the pumpkin. What do i do on this situation???
Old Nov 6, 2013 | 10:54 AM
cougar's Avatar
The leaf springs shouldn't be any thicker, only arched more so you don't need to change anything. The rear may or may not use different spacer blocks. That is when you will need different U bolts.
Old Nov 7, 2013 | 04:16 PM
u2slow's Avatar
The inboard attachment is not a u-bolt, but rather two independent studs threaded into the cast pumpkin. The are usually quite rusted, and its a very good idea to replace them.
Old Nov 7, 2013 | 08:00 PM
So do I have to get longer studs or does it not matter with the new springs. Im going to put a 2 inch lift on.
