6.0 problems rough idle coolant smell
Old Oct 26, 2013 | 06:57 PM
bajahigh's Avatar
Default 6.0 problems rough idle coolant smell
ok so i got my first 6.0 2 weeks ago and now it seems to have a bit of a rough idle and have smelled coolant twice now no its not coming out of the degas bottle but when i parked 20 min ago i could hear the degas bottle hissing like it had alot of pressure n it does seem to be a lil low on power yet the other day when i drove it to school it ran like a bat outta hell n was a bit faster then usual so are my gaskets about to go am i already fucked?? would some standyne fuel additive help the rough idle and change the degas cap help?? need help fast here please
Old Oct 26, 2013 | 09:46 PM
Adrenaline junkie's Avatar
I would pull the egr valve and look at it closely. It should have dry residue on it. If its gooey you probably need an egr cooler. . . If its ok I would change the cap and see if its over pressurizing your tank.
Old Oct 27, 2013 | 01:19 PM
bajahigh's Avatar
ok thank you ill check and let you know would that cause the rough idle tooo??
Old Oct 27, 2013 | 06:26 PM
It can. . .make sure your coolant is clean and always use motor craft recommended coolant only! The generic coolant clogs up the egr and oil coolers! Proper maintenance is critical on a 6.0 but worth the effort! There are lots of posts here with what works and common mods to get more power and life out of your truck.
bdbfam
Aug 31, 2015 09:06 PM
timracerx
Apr 14, 2015 10:28 AM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
