Weird Starting Issue
Old Oct 26, 2013 | 05:23 PM
1st Diesel's Avatar
Default Weird Starting Issue
I have a 2003 F250 6.0 CC SB Fx4 with 160,000 miles. Last year and a half I have done 3 injectors, 2 batteries, ICP, IPR, HPOP, and FICM. I'm due for an oil change but am having a weird starting issue. I have to spray starting fluid in the air filter in order to start the truck. This oddly is whether it is cold or hot, it doesn't seem to matter. I could run the truck all day, shut it off for 10 min, 30 min, 1 hour, doesn't matter, I still have to spray it to start it. Major inconvenience in costs of starting fluid. I'm at a major loss of ideas of what it could be. I've had a few suggestions of spark plugs, but my concern with that, is if it were glow plugs then why wouldn't it start right up without starting fluid when the motor is warm since it doesn't use glow plugs when they are warm. Any and all help will be VERY greatly appreciated. I am extremely stressed out about it and getting very overwhelmed. Thank you all that respond for your help.
Oh and no CEL or any codes.
Last edited by 1st Diesel; Oct 26, 2013 at 05:23 PM. Reason: Automerged Doublepost
Old Oct 29, 2013 | 04:25 PM
1st Diesel's Avatar
no one really has a clue?????
Old Oct 29, 2013 | 05:34 PM
Adrenaline junkie's Avatar
Can you check oil pressure with a good gauge before it starts?
Old Nov 4, 2013 | 09:06 AM
Dustindavisusmc's Avatar
stop using starting fluid#1, and you have a highpressure oil leak, stand pipes and dummy plugs or an injector or stc fitting something of that nature... your only hurting your truck with starting fluid..
dskewes14
Sep 14, 2015 09:19 AM
06kyleP
Jul 19, 2015 06:10 AM
Squirt
Jun 19, 2015 12:40 PM
pcredneck03
Mar 22, 2015 05:51 PM
custom7.3
Nov 24, 2014 05:16 PM
