Lower idle further?
Old Oct 25, 2013 | 08:38 PM
No_chip_92's Avatar
Default Lower idle further?
Hey there, I have my fuel screw in about 2 1/2 turns. Idle was about 850 with the idle screw backed all the way out and the throttle plate riding on the ear where the idle screw is. I bumped the timing last night, and now it idles around 1000. This is WAY too high for my liking. Any suggestions besides re-clocking the throttle shaft/plate? I would prefer not to modify the plate, but am willing to as a last resort.
Old Oct 25, 2013 | 09:28 PM
dan123dbl's Avatar
Re-clocking is the easiest method in my opinion. You'll get more throttle travel out of it as well. You can also grind the lever that goes against the idle adjust screw.
Here is the sticky for that:
https://www.dieselbombers.com/89-93-...r-ve-pump.html
Old Oct 25, 2013 | 09:31 PM
No_chip_92's Avatar
Re-clocking gains more travel but a higher idle, does it not?
Old Oct 25, 2013 | 09:34 PM
dan123dbl's Avatar
Depends which way you clock it. I would re-clock to get more travel and grind off the arm until you've reached your desired rpm. (750-850)
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
hunt4beer
Nov 15, 2014 09:06 AM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
