Adrenaline Install Question
Old Apr 12, 2008 | 10:06 AM
yj junker's Avatar
Default Adrenaline Install Question
I'm in the middle of the install of my adrenaline and I can't find the DATA LINK connector ,this is really starting to **** me off I have most of the wiring harness pulled off and to get any farther forward i may have to remove the power steering pump,any sugesstions ? and the bok says it comes w/ the fuel press.sending unit but i did not recieve it so i called Quad and they said they would send me one once they got a bug worked out?
Old Apr 12, 2008 | 10:40 AM
busta's Avatar
you want to wait til they find another supplier for the fp sending unit
I got one they used to use and it starts at 10 psi and then after about two minutes drops to 0 and stays there
they gave me a part # for e-gauges.com but its back ordered
Old Apr 12, 2008 | 11:03 AM
DB Admin's Avatar
Banned
Locate the truck’s data link connector. This will be a male, black, three-pin, flat
connector on 01-02 trucks, or a gray, three-pin triangle connector on 98-00 trucks.
This connector will be located on the driver side of the engine. The exact location
will vary some from truck to truck but it should generally be located around the
driver’s side motor mount. (Image A-12)It may be located further toward the front
of the motor on some trucks. This plug can sometimes be difficult to locate as it
can be hidden amongst the factory wiring harnesses; you may have to move some
of the factory wiring harnesses to locate it. There will also be a dummy plug connected
to the data link. Once located, remove the dummy plug and connect your
respective style data link plug (purple and pink wires) from the Adrenaline harness.
Look at the ECM it should be at the bottom of it in a big harness
Old Apr 12, 2008 | 11:09 AM
busta's Avatar
Old Apr 12, 2008 | 04:31 PM
yj junker's Avatar
thanks guys gonna go try to find it again i was checking in the main harness but i see that it may be in a smaller harness according to busta 's pics
found the plug and was it a long ways away from the motor mount, its was up front by the engine id tag,tried it out and WOW what a difference now just to figure out what does what and get the tranny temp. hooked up really needed the boost in hp to compensate for the new 315/75 /16 nitto terra graplers
450r racer
8
Dec 21, 2015 06:42 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
MAC4232
Oct 16, 2014 04:22 PM
scottxmorris
Oct 8, 2014 02:14 PM
