24 Valve Rough Idle/miss
Old Oct 23, 2013 | 10:52 AM
anderson92's Avatar
Default 24 Valve Rough Idle/miss
To start this off my pickup is a 1999 2500 24v, has 175hp injectors, Raptor LP, Headstuds, 110lbs Valvesprings, 2 year olds Vp44, 5" straight pipe,edge Drag comp programmer, southbend clutch, and thats all i can think of at the moment. Last Sunday i was on a trip home (100 mile roundtrip) and 10 miles from town my pickup started acting funny. Like a miss/pop. Boosted when i put the pedal down but popped and smoked gray. I went slow and took gravel to get home and by the time i got to town it idled rough and smoked like a freight train. Im thinking injectors but i really Would like some input! 142,000 miles, and was running great. The problem happened at 70 mph just cruising down the highway. Any Help would be appreciated! thankyou.
Old Oct 23, 2013 | 06:17 PM
jigabop's Avatar
possibly a cracked injector or two, improper pop pressures, or an IP going bad...
any codes?
Old Oct 23, 2013 | 07:49 PM
anderson92's Avatar
What are the chances its my IP? and ill put the scanner on it tomorrow.
Old Oct 24, 2013 | 11:19 AM
jigabop's Avatar
codes will tell.
Old Oct 24, 2013 | 06:13 PM
anderson92's Avatar
Default Update
Checked for codes today, nothing came up.
Old Oct 24, 2013 | 10:11 PM
jkidd's Avatar
sticking injector nozzle ?
fuel lubrication can help if its not bound.
Old Nov 15, 2013 | 10:59 AM
anderson92's Avatar
Update. Changed my Injectors, ones that were in it were stock (guy i baught it from lied) installed 100hp DDP's and now runs better but still smokes white and idles slightly rough. What do you think?
Old Feb 8, 2014 | 04:26 PM
Razdad's Avatar
My 98 24 valve is doing the same thing but no white smoke.The previous owner said he put new lift pump on between 140,000 and 198,000 and it has 202,000 now any ideas
Old Feb 8, 2014 | 05:01 PM
anderson92's Avatar
I changed the injectors in mine but still missed, turned out to be a broken push rod..is urs a 12 or 24 valve?
Old Feb 9, 2014 | 01:30 AM
Razdad's Avatar
24 Valve.It does not smoke any(except for morning starts&even then not much white smoke)and today drove to local Wal-Mart(2 get some 2-cycle oil)and it took 3 times to start(has always started 1st crank)after about 30 minutes waiting.Could it possibly be Head Gasket?My temp gauge has never been past 200.I need some help!
