Fuel pressure gauge install?????
Old Oct 21, 2013 | 10:50 PM
Lbarsnick's Avatar
Default Fuel pressure gauge install?????
Hey guys I have spent i ton of time trying to find the best way to hook up my fp gauge. I think I am going to go the route of hooking it straight into my vp. Have seen a hose set on genos garage that hooks straight into the vp test port. I don't know if someone has done this. Does it work good? Also what is better a snubber or needle valve. I am at a loss here guys. Anything help would be nice. Pics of an install would be amazing. Thanks in advance.
2001 dodge ram 2500; edge comp, pacbrake exhaust brake, s&b cold air intake
Old Oct 22, 2013 | 11:05 AM
jigabop's Avatar
get a tapped banjo bolt and hook it to the bottom of your fuel filter canister on the line that goes from the fuel filter to the vp44.
use a needle valve. it seconds as a shutoff valve, and can be set to be more restrictive than a snubber which is a good thing.
you want to just barely crack open the needle valve. if the gauge takes several seconds to sweep to full pressure reading, then it is set perfectly.
how to hook it up:
Old Oct 22, 2013 | 12:17 PM
Lbarsnick's Avatar
Thanks for the info. Another question? I see that your guage is a mechanical one. I have a electrical one. Will this work for the electrical guage also? Some people put a hose inbetween the Sensor and neddle valve. Is this important or can I just hook the sensors into the neddle valve without the hose?
Old Oct 22, 2013 | 04:40 PM
jigabop's Avatar
you can hook the sensor the the needle valve without a hose...just make sure that needle valve is just barely open.
Old Oct 23, 2013 | 04:25 PM
Lbarsnick's Avatar
Where did you get the needle valve from? I am having a hard time finding some.
Old Oct 23, 2013 | 06:22 PM
jigabop's Avatar
you can get them at most hardware stores if they carry stuff that goes that small. like true value, McLendons, Ace, etc...
Napa also carries them.
or if you don't mind waiting a few days, Diesel Auto Power has them and can ship one out to you.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
