Front end help
Old Oct 20, 2013 | 01:26 AM
W.H.Andrews's Avatar
Default Front end help
This is my first post here. I've got quite a bit of play in my steering wheel. About 2". I'm not sure what parts I should be looking to buy to resolve this. Any help?
Old Oct 20, 2013 | 10:47 AM
cougar's Avatar
The most common failure is the coupler between the steering shaft and steering gear. The rebuild kits are cheap, but a lot of people replace the steering shaft with a Borgsen. That eliminates that coupling that always goes bad.
Old Oct 20, 2013 | 11:47 AM
Thanks for the info. I'll give it a shot. Any thoughts on steering components?
Old Oct 20, 2013 | 12:30 PM
cougar's Avatar
Is it 2wd or 4wd?
A good place to start is have a friend slowly rock the steering wheel back and forth while you watch.
typically, that much free play is the coupler. However, I did have a worn out steering column bushing cause the same thing.
The drag link.
Steering box loose on the frame.
Old Oct 20, 2013 | 01:44 PM
It's 4wd. I'm gonna grab everything. Tie rod ends, drag link and Borgsen steering shaft. I've only had the truck for a month. I doubt any of these have been replaced. They look worn and there is play. Do you know if it's a 3500lb or 4500lb front axle? I'm guessing 4500. I still need to check the steering box. Thanks again for the help.
Old Oct 26, 2013 | 09:57 AM
cougar's Avatar
4500# Dana 60. Be careful, a lot of parts places don't understand they are different and try to hand you Dana 44 3500# axle parts.
Old Oct 27, 2013 | 09:27 PM
Thanks a lot. I ordered everything in. Installed the D-link and ball joints yesterday. It was a breeze. Still waiting on the steering box and shaft. I gotta say, I'm really exited to work on this truck. I took the front wheels off and there was tons of room to work. It's a dream. Thanks again for your help Cougar.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
