Stacks???
Old Oct 19, 2013 | 02:42 PM
CumminsPower95's Avatar
Default Stacks???
I've been looking into getting dual stacks but don't know anything about it, I want them to be cut angled at the cab to not come over it, what's the process I have to go through? Will muffler shops do it? I've heard they won't because they can't cut a hole in your bed?
And can I get it ran from the 4 inch turbo back I have now? Or have to get new pipe through out?
Last edited by CumminsPower95; Oct 19, 2013 at 02:42 PM. Reason: Automerged Doublepost
Old Oct 19, 2013 | 06:06 PM
lauber_03's Avatar
Most kits come with flex pipe and you can use your 4inch you have. As far as muffler shops idk i would just cut the hole in your bed mount the bottom pipe and adjust stacks so they dont go over your cab. Measure the top of your cab down your bed to see how long it is so you get stacks the right length
Old Oct 19, 2013 | 07:46 PM
Alright thanks.
I'll look into it what do you advise like just using a torch to cut my bed? Or what? Can it anyway catch the diesel and blow up? Haha
Last edited by CumminsPower95; Oct 19, 2013 at 07:46 PM. Reason: Automerged Doublepost
Old Oct 19, 2013 | 07:59 PM
lauber_03's Avatar
I used a drill then jigsaw
Old Oct 19, 2013 | 08:01 PM
Thanks for the help.
Old Oct 20, 2013 | 05:23 AM
DPDIESEL's Avatar
Try to keep the piece you cut out whole. Then it can be welded back in when your done with the stack phase and you won't have the hole in your bed for everything to fall through.
tim12valve
May 29, 2015 05:19 AM
tbreddiesel
Thoroughbred Diesel
Oct 14, 2014 07:44 AM
