How to install 2012 6.7 cummins smoke switch
Old Oct 18, 2013 | 10:07 PM
Johndeere50's Avatar
Default How to install 2012 6.7 cummins smoke switch
Done a lot of research but can't find out how to do this any help would be appreciated!
Last edited by Johndeere50; Oct 18, 2013 at 10:51 PM. Reason: Wrong wording in title
Old Oct 19, 2013 | 12:58 AM
H.R.D's Avatar
My advice, forget about a smoke switch. The smoke switch has to be the dumbest invention for a diesel. Start doing some research on tuners/programmers that will increase mileage and performance.
Old Oct 19, 2013 | 08:28 AM
mad Keep your opinions to yourself
I was not asking for any opinions about smoke switches just advice on how to install one. I do have all the deletes and a smarty programmer I just want to add a smoke switch, I don't care to hear anything but what I asked for. Thank you
Old Oct 21, 2013 | 06:52 PM
H&SCummins's Avatar
I would also like to know how to wire a smoke switch, all I need to know is which wires to use. I have a 2012 cummins.
I have a H&S Mini Maxx and the only time I can get it to smoke is when its on Performance mode and I get on the throttle but it doesn't put out that much smoke.
If someone else could tell me how to be able to roll heavy smoke ill try it
Old Oct 21, 2013 | 06:57 PM
I finally talked to a man at North Texas Diesel Performance in Lewisville Tx, and he told me that dodge reconfigured how the map sensor works and thus eliminated the effects of the smoke switch. This started on the 2010 and up, if I find another way I will post the results.
Old Oct 23, 2013 | 12:45 AM
Jameswest2434's Avatar
the switch works just fine on my 2011. but that is saved for the gravel roads after work
Old Oct 23, 2013 | 08:37 PM
coors_man_2005's Avatar
How to install 2012 6.7 cummins smoke switch-turboposter.jpg problem solved who needs an extra switch
Old Jan 5, 2014 | 01:49 PM
vds002's Avatar
Which wires did you tap on your '11?
Old Jan 5, 2014 | 02:51 PM
Question
How did you rig up the smoke switch?
Old Jan 9, 2014 | 12:15 PM
Tomeygun's Avatar
I get the "smoke tune" question alot on another forum... These newer ECMs really are strict when it comes to comparing values to deliver fuel.
I know its next to impossible with just a tuner.
