Thumping sound out of cold air intake. Normal?????
Old Oct 18, 2013 | 07:28 PM
Derf's Avatar
Default Thumping sound out of cold air intake. Normal?????
I have a 2006 dodge cummins after installing a cold air I started to hear a thumping sound I believe is coming from the air filter is this normal or not?
Old Oct 18, 2013 | 09:16 PM
dangerous1965's Avatar
Run it with the intake off the turbo to be sure where it's coming from. Not normal isolate the noise I've heard that from the exhaust burnt valve Hopefully not that!
Old Oct 18, 2013 | 11:24 PM
Derf's Avatar
The truck runs great. what other symptoms should I look for if it is a burnt valve?
Old Oct 19, 2013 | 09:17 PM
Smoke and the noise coming out the exhaust pipe! Did you pull the intake off?
Old Oct 19, 2013 | 10:43 PM
Derf's Avatar
No smoke or noise out of exhaust. Same sound with out intake. It's like a hollow thumping I hear it more when I stand far from the tuck while idling
Old Oct 21, 2013 | 08:23 AM
Post a video with sound. Valve adjust good?
Old Feb 26, 2023 | 09:04 AM
DarkEdge's Avatar
I have the exact same thudding on my 95 cummins. Has any found a solution yet
Old Feb 26, 2023 | 09:06 AM
DarkEdge's Avatar
I'm thinking either injector or valve. No blow bye in crank case or coolant. No smoke out tailpipe unless I give it the onion. But that's normal. It dose white smoke and miss if I give it gas when cold in neutral until it warms up. She dosnt like cold starts either. Kinda has a miss for the first couple seconds. Always been like that. But the thudding in the intake just started
May 5, 2013 03:20 PM
redneckpipeliner
Apr 6, 2013 04:36 PM
red11
Mar 25, 2013 09:16 AM
MontanaTechPetroleum
Mar 11, 2013 05:06 PM
jball2500
Chevy/GMC Duramax 2011 LML
Jan 24, 2012 11:22 AM
