04 cummins hard starts and stalling
Old Oct 16, 2013 | 04:37 PM
kyplowboy86's Avatar
Default 04 cummins hard starts and stalling
Ok been researching on here and my truck showed all the signs of lift pump going out. Not a problem so I changed it. Now the truck starts good but when I stomp on the throttle it stalls and sometimes dies. Let it set and it starts back seems fine then when accelerating it goes back to stalling. New pump shows that I have a full tank of fuel now. Chance I just got a bad pump?
Old Oct 16, 2013 | 06:41 PM
blue streek's Avatar
Hello
I am new to this but did just learned one good lesson. My lift pump went bad when I had debris in the tank. Lift pump got clogged - ran for a while but when you hit the pedal (need more lift and pressure) truck ran bad.
Installed new lift pump and cleaned the tank - so far so GOOD
You might of received a defective lift pump. Check lift pressure if you can
Old Oct 16, 2013 | 08:20 PM
Well found problem, broken power wire
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
RatsMC
May 4, 2015 05:25 PM
