fuel presssure gauge
Old Oct 16, 2013 | 03:16 PM
Redram01's Avatar
Default fuel presssure gauge
I have a isspro fuel pressure gauge with the snubber valve and it has a rattle in the gauge. The pump is airdog frrp. thanks for the help.
Old Oct 16, 2013 | 05:47 PM
jigabop's Avatar
sounds like your snubber is junk.
get yourself a needle valve to replace it with 1/8NPT male to female which you can find at most hardware stores, or napa. Open the needle valve just barely a crack to have the proper setting. the needle should take several seconds to sweep to full pressure. if it pops over to full pressure instantly, it is open too much.
that buzzing sound from the gauge means injection pump pulses are hammering the crap out of your gauge. if caught early enough the gauge will be fine..but if you let it go on for too long it will destroy the gauge.
Old Oct 17, 2013 | 10:28 AM
Redram01's Avatar
Thanks for the help
Old Oct 17, 2013 | 01:39 PM
jigabop's Avatar
no problem.
my gauge buzzed at one point, and I just closed off my needle valve more to what I described, and it hasn't had an issue since.
Dbleo351
Nov 20, 2016 09:34 AM
Steve123
Sep 28, 2015 02:36 PM
ctjkelley
Jun 3, 2015 06:01 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
