Fuel Pressure Gauge with a FASS question
Old Oct 14, 2013 | 11:00 PM
Texas Pride's Avatar
Default Fuel Pressure Gauge with a FASS question
I have an 01 with a FASS that has the separator and filter in it so the stock filter housing was removed and I am fixing to install a fuel pressure gauge. Is tapping into the test port on the VP44 the best way to install my sensor?
Old Oct 15, 2013 | 09:36 AM
RAW's Avatar
RAW
A tapped banjo bolt with a snubber is a good way to do it.
Old Oct 15, 2013 | 07:44 PM
jigabop's Avatar
no
if he has a full line kit which he likely does, then there is no longer any banjo bolts on the input side...
solution: tapped 90* pushlock to JIC fitting... also use a 1/8 NPT needle valve as a snubber. just barely crack open the needle valve for the correct setting to stop the injection pump pulses.
Old Oct 15, 2013 | 10:05 PM
RAW's Avatar
RAW
I have heard of using a 24" grease gun line and mounting the sensor on the end of it to reduce the pulses. Might do it myself once I replumb my system.
Old Oct 16, 2013 | 05:12 PM
jigabop's Avatar
that doesn't help much. needle valve is your best and cheapest option. they work better than snubbers if closed off enough.
you want it closed enough that it takes a few seconds for the gauge needle to sweep to the pressure.
my gauge takes 2-3 seconds to fully sweep to my idle fuel pressure.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
