single to dually
Old Oct 14, 2013 | 10:48 AM
scottmorgan's Avatar
Default single to dually
ok simple question.. can I put dually rims on my single wheel rear truck? I don't see why not... I will buy a spacer that will allow me to bolt these on my truck I am running a flat bed that was meant for dually any how.. is it as simple as the right rims and the spacer?
Old Oct 14, 2013 | 11:26 AM
AMS247's Avatar
No. A SRW axle is not meant for a DRW set-up even with a spacer to clear the brakes. Reason is because the DRW wheels are hub-centric, where as your SRW are lug-centric. If you use a spacer to push the inside wheel out, both of the dual wheels will not be aligned on the hub to properly fit them.
Yes of course the wheels will bolt up if you choose to run a set-up like that, I HIGHLY suggest NOT going that route.
Your best bet will be to find DRW Dana 80 to drop in your truck which would be all bolt on. If your truck came with that 6 speed, you should already have the Dana 80 Hybrid under there so you won't have to worry about modifying your rear drive shaft since the center sections are the exact same.
Old Oct 17, 2013 | 12:44 PM
alright thanks for the heads up and yes I currently have the dana 80 but I have no clue were im going to find one..
Old Oct 17, 2013 | 01:53 PM
AMS247's Avatar
Craigslist.. I seem them on there all the time, and have sold a few myself. I would expect to see a factory Dana 80 DRW sell for $400 - $550. If you find one though, it'll be a straight bolt up, depending on which year you get, any earlier than 01' you'll have drum brakes.
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
Ward_59
May 12, 2015 04:39 AM
Brokencummins
13
Apr 20, 2015 01:05 PM
jerm89
Feb 17, 2015 08:19 PM
joseywales
Jan 16, 2015 08:44 AM
