cannot get 1st gen to run
Old Oct 13, 2013 | 12:28 AM
tom88k5's Avatar
Default cannot get 1st gen to run
Doing a cummins swap into my 95 dodge. Boaught the motor about 6 months ago. Has new inj pump when I picked it up the guy cranked it up for me and it purred like a kitten. Now that ive got it in my truck cannot get it to crank. I have a brand new elec lift pump. I bypassed manual lift pump removed plunger from stop solenoid. While cranking have inj cracked start getting fuel start closing them off and then just shuts down and have to start all over again. Plz help!
Update.... got it to run on 3cyl 2 5 and 6 cyl 1 3 and 4 barely push any fuel at inj and inj pump. Bad pump maybe?
Old Oct 13, 2013 | 09:11 AM
db Zac's Avatar
So it's a VE pump Cummins? Did you bleed the system of air 1st?
Old Oct 13, 2013 | 09:26 AM
tom88k5's Avatar
Yes. Cracked bleeder at filter housing till no air was present, cracked feed line at pump till no air was present, even cracked return line on pump.... no dice.
Old Oct 13, 2013 | 10:36 AM
cougar's Avatar
Check the manual shut off lever and keep bleeding. It can take a while to get all the air out.
Old Oct 13, 2013 | 10:38 AM
tom88k5's Avatar
Checked that too. Let it run for prlly an hour with lines cracked... no dice
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
myago92
Oct 17, 2014 08:50 AM
93 gulfstream
Oct 5, 2014 09:46 PM
