Head Studs or not?
Old Oct 12, 2013 | 04:17 AM
Kbanic's Avatar
Default Head Studs or not?
Thinking about putting the High Performance SSD-Chip the 80hp on along with a number 9 performance resistor. then eventually the 40hp injectors. do you guys think head studs are necessary. i was leaning towards yes but then my diesel tech teacher told me even then i wouldn't be making enough power to need head studs.
Old Oct 13, 2013 | 04:34 PM
racer55's Avatar
Head studs are always a good idea at head gasket or rebuild time.ARP sells them as 6.2 studs(130-4062) but they are the same-follow the install procedure to a T.
The benefit of head studs is magnified even in stock configuration because the block was designed with too few fasteners around each cylinder bore-better clamping force is required to contain the seal even in stock form.
Avoid marine injectors-there is no benefit to them on a truck,they only perform better when paired with the marine mechanical IP.
Stock turbo bosch injectors can flow more fuel than the IP can deliver.
SS Diesel is a rebranded Westers Garge tune that is out of date-much better tunes available from Buddy,Kennedy Diesel,Heath Diesel or KOJO.
The Buddy Tunes 6 postion multi tune is what I would go for with a 94/95.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
