Misfire
Old Oct 9, 2013 | 08:34 AM
edoerges's Avatar
Default Misfire
3rd Gen, I love the truck. It went into limp mode, I had the turbo checked, and it’s good. Put a new waste gate actuator and solenoid on it. I changed the air temp sensor, manifold presser sensor. It had a code 2146. I ohmed out fuel injectors and found a bad one, I changed it and the harness and fuel filter. It ran good for about 5 minutes and then it threw codes 300, 304 and 306. Which is misfires in cylinders 4&6. What else can it be? What have I not looked at? I need my truck! Any help will be appreciated.
Ed
Old Oct 9, 2013 | 10:16 AM
dangerous1965's Avatar
Clean all your grounds and check the harness plug to the injectors! Clear the codes. If one injector was bad probably all need to be replaced.
Old Oct 11, 2013 | 08:29 AM
edoerges's Avatar
Default misfire
thanks i will be changing the harness connectors this weekend and cleaning grounds. Hope thats it.
Old Oct 11, 2013 | 10:09 AM
jkidd's Avatar
if the harness does not fix it we can test the injectors for $15 each.
Old Oct 14, 2013 | 12:37 PM
edoerges's Avatar
Default misfire
After changing the connectors on the injector harness and cleaning all the grounds, it seemed to fix it, but now I have a knock. When I took the rocker arm off and did not touch the adjustment screw. Could it have gone out of adjustment? The oil level is good.
Thanks
Ed
Old Oct 15, 2013 | 08:27 AM
Run the valve adjust just because!! Knock can be several things from nothing to OMG!
An injector dumping fuel will do it as will a valve seat. Even a programmer can do it but start with the valve adjust!
Old Oct 17, 2013 | 08:12 AM
edoerges's Avatar
hey thanks, i found it,
I got home and it was still knocking, i did not think it was valve adjustment cause i did not touch it and it ran fine before. So I took off the valve cover and started it and then took a wire off of the injector i just replaced. Go figure the knock stopped.
so I got a bad one.
going to call them up today and have them send me another one.
thanks again
Ed
Old Oct 17, 2013 | 11:00 AM
I hope that's what it is and not a bad piston be sure to boroscope the cylinder when you get the injector out!
Old Oct 17, 2013 | 04:27 PM
edoerges's Avatar
bad meaning what? its not smoking at all. never had.
Old Oct 18, 2013 | 06:52 AM
melted piston. Common on trucks that lose a injector and run for a while without knowing it. Put a camera down the hole just for piece of mind! Rare that a new injector is bad but possible! I'm just guessing without actually seeing it! Valve seat still comes to mind but depends on the year early models 03 04 more likely.
