98 drive belt
Old Oct 5, 2013 | 03:08 PM
blacksally's Avatar
Default 98 drive belt
i replaced the drive belt on my 98 6.5 b/c the old one was old and tore then new one I drove 45 miles and it did the same it looks like its all lined up but the crank pully its hitting the edge as if the pully isn't on all the way but I checked the bolts all tight is this a serious thing truck runs good no problems other then this thanks
joey
Old Oct 5, 2013 | 05:29 PM
racer55's Avatar
more likely a problem with the tensioner.
Old Oct 5, 2013 | 09:06 PM
blacksally's Avatar
ok should I try a new tensioner with belt?i was gunna put a new pully on the tensioner but the bolt wont tighten up its stripped im guessing
Old Oct 5, 2013 | 09:14 PM
racer55's Avatar
Most belt problems come back to the tensioner but with the belt off spin all the pulleys and make sure they have good bearings ect.
Old Oct 5, 2013 | 10:44 PM
blacksally's Avatar
I did check and make sure they all felted right no bearing noise etc looked good but the belt was riding almost on the ridge of the crank pully then it ripped so cut it off
Old Oct 8, 2013 | 11:34 PM
blacksally's Avatar
the vac pump pully wasn't all the way on I used a power steering pully installer and got it!
Old Oct 9, 2013 | 07:24 AM
racer55's Avatar
Good Catch!
Ironmanqb
Apr 4, 2015 10:27 PM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
mnbf48
Jan 19, 2015 09:20 PM
