2002 24v water will not.drain.from fuel filter
Old Oct 4, 2013 | 11:08 AM
Cumminsambitionist's Avatar
Default 2002 24v water will not.drain.from fuel filter
hey all, I have. a 2002 24v. I bought.it.took.it.on a.cross.country.road.trip. and I went to drain my fuel filter and it wouldn't drain. it sounded like it almost sucked air.in. so I changed the.filter and.it.was fairly new, but there was.dirt.in the filter housing. so I cleaned.it out and tried.again 500 miles later but.again it sounded like it sucked.air.in.and.nothing.drained.out. any ideas?
Old Oct 4, 2013 | 12:06 PM
jigabop's Avatar
probably either clogged, or there is just no water in there?
I have an aftermarket filter system that seems to work extremely well at filtration and water separation.
(airdog150 with fleetguard filters)
Old Oct 4, 2013 | 10:19 PM
4x4manonbroke's Avatar
Open th Spout @ bottom and push a small piece of coat hanger up in the hole .. should empty real quick then clean it out as best as possible
Old Oct 4, 2013 | 10:26 PM
brickhouse15's Avatar
give the inside a good once over with brake cleaner then wipe it clean.
Old Oct 5, 2013 | 11:05 AM
Hey thanks for the quick responses i will try both, and i ordered an airdog 100 to install and hopefully make the truck a little more reliable. I'll give em a shot this weekend, have a good one yall
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
