Highway RPMs seem high?
Old Oct 2, 2013 | 06:34 PM
No_chip_92's Avatar
Default Highway RPMs seem high?
Hi there, first off my sig is my mods. Truck pulls fine around town and seems like the tranny isn't slipping.. I get on the highway, doing 100 km/h (60 mph I think?) my truck is seeing 2400 RPM consistently ! I can verify it is in O/D as it will go in and out and I have to pedal it to get it into O/D so I can do 100.. I have an A518, 3.54 gears as far as I know, and this seems obnoxiously high.. Any advice or anyone else seeing these kind of rpms?
Old Oct 3, 2013 | 12:30 PM
dan123dbl's Avatar
1:1 (3rd) ratio with your size tires you should be running 2169rpms at 100km/h.
.69 (OD for the a518) you should be turning 1496.
Bad torque converter maybe?
Old Oct 3, 2013 | 05:18 PM
u2slow's Avatar
Something's off for sure. Getting on the pedal should kick it down to 3rd (1:1) not up into OD.
FWIW, I think you are due for a governor spring before you do anything else.
Old Oct 3, 2013 | 05:47 PM
No_chip_92's Avatar
Truck fuels past 3500.. I can free rev to 4K (not that I do) but I have verified at more than one stoplight that it will fuel up top . Anyway to check the TQ? I'm doing a fluid/filter change as we speak and am going to turn up the line pressure and tighten the bands..
Old Oct 3, 2013 | 05:53 PM
cougar's Avatar
I would say your tach is wrong.
Old Oct 3, 2013 | 10:35 PM
No_chip_92's Avatar
I'm pretty sure my tach is on.. Prior to my throttle rod and high idle shaft removed, it free idle to 2800 or so. The only thing I can think of is that either a) the TQ fins are bent/melted from PO causing a false higher stall speed, or b) the PO changed gears to 4:10s.
Old Oct 4, 2013 | 12:45 AM
dan123dbl's Avatar
Even with 4.10s your rpms should be about 1800.
You can check ratios using this calculator at the bottom of the page : Engine RPM Calculator
Old Oct 4, 2013 | 03:07 PM
cougar's Avatar
My 92 at 55mph runs at about 1650-1700 RPM on a factory tach. 235/85R16 tires and 3.55 gears.
Old Oct 5, 2013 | 10:43 AM
No_chip_92's Avatar
Any sure fire way to check rpms besides another tach? I don't think it could be out almost 1000 rpm, but then again it does spin off the alternator..
Well, I changed the fluid, filter, adjusted the bands on the tranny and bumped the line pressure a bit and now it seems to run 2300 or so. There were very very few metal shavings in the pan, and the fluid was in tip-top shape.
Old Oct 6, 2013 | 09:55 AM
cougar's Avatar
I can, your taking it off the alternator instead of the crank shaft. Gas car and a timing light is how I did it in the good ol days. Used the gasser for a reference and pointed the timing light at the diesel.
