1996 Suburban
Old Oct 2, 2013 | 04:37 PM
texasnative46's Avatar
Default 1996 Suburban
Friends,
I've found a 1996 Chevy Surburban w/6.5L diesel & AT in a pasture in south TX, which is in apparently good shape with only a little less than 100,000 actual miles. -2000.ooUSD!
(It wasn't a "second car". - Instead it was a 4th vehicle for the family & was seldom driven except on long trips.)
To keep it running as long/well as possible, what maintainence should I do to the old truck?
Are there any well-known problems, to that specific model, that should be checked during a PPI?
THANKS.
yours, tn46
Old Oct 3, 2013 | 11:45 PM
To ALL,
125 views but not even one response. - Does NOBODY have actual experience with the 1996 Suburban & RELIABILTY modifications or "special concerns" for that model?
(I'm not very interested in more speed or towing capacity.)
yours,tn46
Old Oct 4, 2013 | 08:39 AM
racer55's Avatar
Clean the cooling stack # 1
Replace/rebuild injectors with Bosch nozles ONLY!
Replace glow plugs with Bosch Duratherm glow plugs,All other electrical parts on these trucks should be AC Delco ONLY!
Get a PMD relocation kit and mount it under/behind frt bumper
replace exhaust with diamond eye kit
replace exhaust crossover pipe with aftermarket
locate and install a stock K-47 air cleaner housing and filter from 97+ 6.5 truck
normal maintenance items-oil change,fuel filter ect.
Open water in fuel drain Tee-valve while engine is running to remove water from filter housing and note if truck stalls-lift pump may need attention?
Make sure that it has diesel fuel filler cap-gas caps are not properly vented.
Do battery cable fastener mod that requires the bolts be replaced by a long 3/8 bolt with a nut on it that is used to tighten the cable.
Those are a few off the top of my head.
Old Oct 4, 2013 | 10:10 AM
racer55,
THANKS.
yours, tn46
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Stone007
Tech Article Submission
Jul 3, 2015 01:28 PM
Radioking1777
Jun 8, 2015 10:26 PM
rajdiesel
Mar 14, 2015 07:11 AM
jrsavoie
Feb 6, 2015 12:32 PM
