Oil bypass recommendations
Old Sep 27, 2013 | 10:53 PM
Polaris04's Avatar
Default Oil bypass recommendations
Hey guys I have a little extra money coming in this month and figured it would be a good time to buy an oil bypass kit as well as a coolant filtration kit. I have a 2003 6.0l the engine is all stock 195k miles. I just had some little questions about both, first of all which brands would you recommend for both? Then for the oil bypass kit how far can I go on oil change intervals (I run rotella t-6 5w-40)? And as far as whichever is the best brand would I still use the stock oil filter? Then for the coolant filtration system? Would you recommend using a particular type of coolant? Right now I think I am running a shell (It was what we had in the ranches barrel). and when I install the coolant filtration kit should I change out the old coolant and should I flush the system in any way? if so with what and how? Sorry for all the questions guys, I don't know much about these two kits! If there is anything else that I am missing and you would like to add I would greatly appreciate it!
Old Sep 28, 2013 | 04:39 AM
HeavyAssault's Avatar
I'm not sold on Amzoil for motor oil but their by-pass filter kits are quite efficient. I for one don't believe in extended intervals so I will run 7500 mile changes never exceeding 10k miles.
You should always run OEM filters, don't trust anything else. You can find a coolant filter and base at the local NAPA. You can get the hoses to tie it all in just like all the others.
I would do a standard flush without using any chemicals. Just run the system clean with distilled water. Then add a ELC rated coolant like Fleetrite.
Old Sep 28, 2013 | 08:03 PM
Polaris04's Avatar
Ok so it sound like I will be going with the amsoil bypass kit, also would you recommend adding some rev-x oil additive? As far as the coolant kit, does anyone have any pictures or instructions on how I could build my own bypass kit? Like I stated above I have no experience with them and have no idea where they tie in and no idea what kind of filter and hose to use. I did see on kit with ball valves so that before I changed filters I could shut off the valve so I done make as much of a mess. And when I flush the system...fill the system completely with distilled water, then run and drain? Thanks for all the help!
Old Sep 28, 2013 | 10:14 PM
Lilpooh's Avatar
You could also go with the BPD oil bypass with the BPD Amsoil filter adapter. This system will allow you to either use the cheaper bypass filters or the Amsoil EaBP series filters. Gives you more options if money is tight when it's time to change filters.
The adapter can be installed or removed for either style bypass filter.
http://www.bulletproofdiesel.com/Byp...ilter_asmb.htm
http://www.bulletproofdiesel.com/Byp..._p/6400084.htm
Old Sep 29, 2013 | 10:27 PM
lenzhotrod's Avatar
I use the raycor BP802 system, It holds 2.5 quarts of oil more and filters down to less than 1 micron. I tapped a tee at the oil pressure sending unit and my return is at the oil plug in the left valve cover and the filter itself is mounted under the vehicle about where the drivers feet are at. To look at the engine you would not even notice the system. The down side is filters are harder to come by and about $25 each, when I use to pay about $7 each.
Old Oct 1, 2013 | 12:15 AM
Polaris04's Avatar
I found a kit that I liked on 6.0 oil bypass filtration system and parts 6.0 billet aluminum filter cap airdog II - Diesel Oil bypass filtration & Coolant kits Ford Powerstroke 6.0 Chevy 6.6 Dodge 5.9 & 6.7 Parts Filters Aluminum oil filter caps Powerstroke Crankcase vent it had both the oil bypass kit and a coolant filtration kit that mounted to the same bracket, what do you guys think? I think I will order it some time this week and try putting it in next Friday when I don't have class.
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
Spk329
May 23, 2015 12:46 PM
coors_man_2005
Dec 15, 2014 10:23 AM
