Advice on Purchase of 99 2500
Old Sep 19, 2013 | 10:17 PM
robertjr93's Avatar
Default Advice on Purchase of 99 2500
I found a 99 dodge 2500 at a local dealership. Asking for 7,000 it has 145,000 miles on it. My question to you guys what should I look for in this truck? What are the major issues that people are having with this truck besides fuel pump issues? I'm new to the diesel world so excuse me if I'm doing something wrong. Also what would be the first upgrades or mods you would do to this truck? Any info will help especially parts cost. Thanks in advance for any help.
Old Sep 20, 2013 | 04:13 AM
97cummins's Avatar
One of the first mods I would recommend is for the fuel system. I have talked to people with that year motor that recommend that the draw straw be installed into the fuel tank, and the main fuel line be upgraded to I think they said it is a 1/2" from the fuel tank to the fuel pump. That way fuel is always pumped to your fuel pump and it doesn't burn up your fuel pump from lack of fuel.
Old Sep 20, 2013 | 11:03 AM
jigabop's Avatar
usually a fass150 or airdog150 has 1/2" draw straw and 1/2" fuel lines from the tank to the injection pump. (like mine)
check if it is a 53 block or not... will either have raised numbering on the drivers side of the block, or it will be stamped in... its on the block right above the oil pan. bout an inch tall.. 53's tend to be a weaker block that may or may not crack on the passenger side above the freeze plugs and leak coolant.
if it isn't cracked and is a 53 I wouldn't really worry about it.
and if I was looking for a truck, I would look for a 4x4 with a manual transmission...
Old Sep 24, 2013 | 10:53 AM
robertjr93's Avatar
Here is a link to the truck. 1999 Dodge Ram 2500 2500 4WD | Used Ram 2500 | Dublin, GA | 1B7KF23Z5XJ563269 Whats the best way to go about finding if it has the 53 block?
Old Sep 24, 2013 | 04:32 PM
jigabop's Avatar
look .
Nathanator
Aug 30, 2015 03:51 PM
DirtyDiesel58
Jun 7, 2015 11:50 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
big willy
Diesel Engine Conversions
Feb 24, 2015 09:12 AM
Dec 29, 2014 10:20 AM
