04.5 Cummins - Will barely start after new cp3
Hey guys! I have a problem and I'm kind of at a loss so any help will be greatly appreciated! I recently had my injection pump go bad and replaced it with a industrial injection pump that does 33% more flow. The truck runs great but doesn't want to start. Just when you think it's going to turn over it seems like it looses fuel and stalls. I have to hold the key on through it stalling for the truck to start. I'm being told by a few people it could be my stock injectors can't handle the output of the new pump, and/or the cross-over tubes either need retorqued or replaced. Thanks again guys!
try and start it with the FCA unplugged. Should run and rattle pretty bad! Plug it back in and should smooth out in about 30 seconds. Check for leaks and it wouldn't hurt to throw a wrench on the crossover tubes! Remember to loosen the injector lines first! Find the pressure leak and you'll be fine!
18 ftlbs. did you take off the injector lines?
A CR with disconnected lines being turned over with Billy's hands in there do you know what 20,000psi can do to a hand?! I hope you got it figured out! What's the update?
Torque for injector tubes is 37 ft-lbs not 18.
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
