6.0 rough idle on cold start
Old Sep 16, 2013 | 04:49 PM
bauer2013's Avatar
Default 6.0 rough idle on cold start
Hey everyone I'm new to these posts. I bought a 03 f250 6.0 from a buddy's dad about 2 months ago and it ran awesome until about a week ago.I'd start it up in the morning and go to work and it'd run like **** until it got up to operating temp. It stared getting worse and worse since it began. Now if it sits over night and I go to start it in the morning, it will fire up and kill. So then I turn it over again and it'll stay running but it sounds like its misfiring. Once it sits and idles then it starts to sound better but when I take off it runs rough and loses power for the first 2 or 3 miles then it runs fine. I've been reading around and have seen many different things that it could be. I just tested the FICM today and it came out to have 48V with the key in the on position and it had 45-46V when it was running. Any help would be awesome as far as what you guys think and what I should do
Old Sep 16, 2013 | 07:51 PM
"LU" the mechanic's Avatar
any smoke when you start it?
Old Sep 16, 2013 | 07:56 PM
farm boy's Avatar
I have a 04 and it was doin the same thing. It took me awhile to figure it out but it got alot worse over time and then my hpop took a crap. you also my just need to do your glow plugs and relay. also what was your ficm voltage while you were turning it over.
Old Sep 16, 2013 | 10:58 PM
bauer2013's Avatar
What's your hpop? I was reading 46 volts when it was cranking over
Yea white smoke for about 20 seconds and then it stopped smoking
Old Sep 16, 2013 | 11:02 PM
dietz4ibanez's Avatar
I have a 04 f450 that did this. Once the injectors were replaced it was good as new.
Old Sep 16, 2013 | 11:05 PM
bauer2013's Avatar
What would you recommend doing? I don't wanna put the money into injectors if its not them forsure
Old Sep 16, 2013 | 11:26 PM
I guess the best thing you can do it have a mechanic scan the truck!
Here is a good video about the Hpop and it shows you the scanned data and what to look for, all in all. I would start pursuing the hpob since the revised parts seem to be almost mandatory.
Last edited by dietz4ibanez; Sep 16, 2013 at 11:26 PM. Reason: Automerged Doublepost
Old Sep 18, 2013 | 11:12 PM
bauer2013's Avatar
Anyone else have any idea what to do
Old Sep 19, 2013 | 04:38 PM
Deadeye's Avatar
buy to bottles of rev x oil additive and change your oil once the oil change is done put the 2 bottles into your oil and drive your truck around for 1/2 hr you should notice a huge improvement on your next start up
Old Sep 19, 2013 | 04:49 PM
bauer2013's Avatar
I just did an oil change 200 miles ago. Is it too late to add it or can I just add it now?
