1993 cummins ext cab 35'' tires fit?
Old Sep 16, 2013 | 11:40 AM
Jasontx's Avatar
Default 1993 cummins ext cab 35'' tires fit?
I have a 1993 cummins ext cab single wheel real tire.
Will 35'' tires fit with stock height?
Thank you very much
Old Sep 18, 2013 | 10:41 PM
MonstarMotorsports's Avatar
no. not with out lots of trimming anyways. 3" lift will clear 35's perfectly. under turn and hard flex i can rub my worn out 35's a little bit. if they were new they'd rub a lot more.
Old Sep 23, 2013 | 10:00 AM
cummins_guy's Avatar
I have 37's on mine, I had to trim the front fenders about 3", had to put a 3" body lift with new cab busings, I had to also put new HD spings and bilistien shocks, that gave me enough room to fit those big tires, oh and I had to put 3 inch blocks in the back to make it look level.
Old Oct 3, 2013 | 05:08 PM
u2slow's Avatar
I had used 35" tires (toyo 315/75R16, probably 34" when I got them) on my W250 - no lift, sagged leafs, no trimming. Biggest problem was they were on Ford 16x7 steelies, and the tire would rub the pitman arm turning right you only got about half the turning angle out of it.
I switched to some used 9.00R16 Michelins up front so I could steer better. Would catch the front fender corners slightly, so I rolled/folded them in a bit.
Jsully
Aug 31, 2015 07:55 PM
yhatzee89
For Sale
Mar 1, 2015 09:03 PM
pkcole
For Sale
Nov 20, 2014 08:11 PM
Jthompson_32
Oct 5, 2014 09:51 PM
