bad radio wiring?
Old Sep 15, 2013 | 04:08 PM
|WYG|SS's Avatar
Default bad radio wiring?
I have a 2002 2500 and am curious If anyone else has had any issues with an after market radio. I just bought a BOSS radio and installed it my self I connected all the wiring properly. The first day I had it kept resetting after i turned the truck off. Then I messed with it at work the other day and I checked the wiring again. The constant and accessory wire are hooked up properly. Then after that it worked up on til yesterday... what do you think about me running a nwe constant ground and splice it into the current constant ground? Otherwise it may be the radio
Old Sep 15, 2013 | 04:53 PM
jigabop's Avatar
factory amp?
Old Sep 15, 2013 | 08:30 PM
|WYG|SS's Avatar
Originally Posted by jigabop
factory amp?
These have amps? If so then yes
Old Sep 16, 2013 | 11:44 AM
jigabop's Avatar
if you have the infinity sound system then yes it has a factory amp on the passenger side behind the dash...dash has to be pulled to access it, and it can be a PITA when you have your own amp...
Old Sep 19, 2013 | 07:15 PM
dango's Avatar
make sure you have no wires shorting out under the dash. its easy to pinch a wire while your installing the new radio.
ofelas
11
Aug 12, 2015 07:23 PM
Feb 5, 2015 12:10 AM
Mike H
Nov 25, 2014 03:13 PM
12vbomber
Nov 11, 2014 10:58 AM
