ROUGH IDLE SOMETIMES
Old Sep 15, 2013 | 02:30 PM
lonestardavid's Avatar
Default ROUGH IDLE SOMETIMES
2003 DURAMAX 4X4 2500HD HAS RECENTLY STARTED IDLING ROUGH WITH LITTLE WHITE SMOKE AFTER ENGINE WARMED UP. CAN SHUT ENGINE OFF AND START BACK UP AND IDLES FINE THEN IN FEW MIN. STARTS IDLING ROUGH AGAIN. HAVE EDGE TUNER INSTALLED FOR TOWING. WHEM CHECKING INJECTOR BALANCE TUNER SHOWS THE BALANCE BUT WHEN IDLES ROUGH THE BALANCE OF ALL INJECTORS GO TO ZERO AND STAYS THAT WAY WHILE IDLING ROUGH BUT WHEN IDLES SMOOTH TUNER SHOW THE BALANCE OF ALL INJECTORS.
Old Oct 4, 2013 | 10:24 PM
4x4manonbroke's Avatar
I would start with the Fuel dilevery system, it almost sounds like your describing a bad IP or low pressure to the IP .... my $.02
Old Oct 4, 2013 | 10:54 PM
2004LB7's Avatar
i would guess its the fuel pressure regulator.
can you check desired vs actual fuel pressure?
Old Oct 5, 2013 | 08:45 AM
yes we checked all that. finally took it to shop and they checked it with scanner and # 2 injector was bad. Had left bank change and he had extra filter set up he installed for more protection. so far she running like a top. thanks for the advice.
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
