Bad Fuel Mileage
Old Sep 10, 2013 | 06:30 PM
BananaBoat_'s Avatar
Default Bad Fuel Mileage
I have a 99 Cummins 4x4 automatic with 170,000 miles running an Edge Comp Box, 5in straight pipe, and a K&N cold air intake. Its currently sitting on 285/75/16 BFG ATs with the tire psi at 60lbs front and 55 psi rear. I have the 3.5 gears. I'm only averaging about 13mpg (about 320 miles to an 1/8 of a tank). I run my Comp Box on 5 timing all the time but the fueling varies. It doesn't matter if I have it to the floor all the time or I drive like a grandpa it stays at 13 on all of the fueling. When I bought the truck completely stock last year it got about 15 mpg average. I also ran a smarty before the Edge and it still sat at 13. I believe it could use a lift pump and some new injectors but I don't know for sure. I also keep up on the filter and fluid changes. If anyone has any other suggestions let me know. Thanks
Old Sep 11, 2013 | 11:31 AM
jigabop's Avatar
brakes dragging?
what is the tire size? I'm guessing you have 4.10 gears...
also what kinda speeds do you cruise at?
your economy is definitely crap...
I get 15.5mpg average city/hwy mixed driving with huge injectors that haze at idle with 4.10 gears and 315/75R16 mud tires...
If I can pull that off without much effort, your truck should be doing far batter...
before aftermarket injectors and turbos, I used to get 17mpg with the same tires and gears.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Mike H
Jan 25, 2015 10:08 AM
