6.5 crank position sensor removal
Old Sep 9, 2013 | 02:39 PM
tntitans's Avatar
Default 6.5 crank position sensor removal
I have located and removed the retaining bolt that holds the crank position sensor. I then tried to use a screw driver to lift the sensor and the metal bracket that holds and positions the sensor broke off. Now I only have the wires leading into the sensor to lift it out with. Using a long off set needle nose pliers I have tried lifting the sensor but there is too much resistance and applying more force would just break the wires. help
Old Sep 9, 2013 | 05:08 PM
Mayhem's Avatar
I had the same experience a couple years ago with my 1994 6.5 they become brittle with age you will have to have a right angle drill start with a 1/8th inch drill bit drill about 1 1/4 inches into the old CSS start with a 1/8 lag bolt 2 inches long get some over sized washers that will fit the bolt without slipping off use a pickle fork or tie rod seperater place behind the washers and start prying out the old CSS you will probaly want to get a few larger lag bolts stepping up in sizes I finally got mine out with a 3/8 or a 1/2 inch lag bolt if you put anything besides AC/delco or I found that Napa has one that looks and performs like the AC you will fix nothing do not use a borg warner or BWD brand Crank Shaft Sensor total waste of money them brands
Old Sep 9, 2013 | 08:21 PM
Rhett73step's Avatar
Exactly as Mayhem said, I did almost the same exact thing. Make sure you don't replace it with a BWD cps, I just earlier today had to replace mine. Didn't realize it but the reason my truck ran like total poo was because of said BWD sensor.
CJ Morin
19
Nov 20, 2018 07:30 PM
Dbleo351
Nov 20, 2016 09:34 AM
ish1521
Aug 26, 2015 08:42 PM
smokin91rs
Jun 2, 2015 09:18 AM
Mr. Walkway
May 11, 2015 10:49 AM
