P0234 - Turbo Boost Limit Exceeded
Old Sep 5, 2013 | 02:34 PM
RoJazz13's Avatar
Default P0234 - Turbo Boost Limit Exceeded
Truck has a chip, but i disconnected it for now. Owner before me said they put in a better turbo. Truck jerks and bucks when I go at high speeds. Any help?
Old Sep 6, 2013 | 12:03 PM
jigabop's Avatar
sounds like a junk "chip"
any decent programmer like a smarty will reconfigure your boost tables to prevent over-boost codes, and any decent fueling box will have a map sensor loop that fools the map sensor reading to prevent an over-boost code.
Old Sep 14, 2013 | 08:21 PM
RoJazz13's Avatar
Took the truck out on the highway again and it didn't hardly jerk at all. It feels like it is only sometimes that its bucking around during high speeds. The chip is disconnected so it couldn't be that. Is there a sensor that could be doing this? Its almost like its acting intermittent. It'll work sometimes, then other times it'll just jerk and buck around.
Old Sep 14, 2013 | 11:41 PM
crazycooter's Avatar
how is your fuel pressure? low fp will cause a bucking at higher throttle position. I would pull codes to make sure it isn't in your ip too
Old Sep 16, 2013 | 06:58 PM
RoJazz13's Avatar
I don't have a fuel pressure gauge on it. I know I need to get one. Went to advanced auto and pulled codes. This is the only code it pulled up. No other one.
Old Sep 17, 2013 | 06:23 AM
Jbremount's Avatar
Do you have an adjustable boost elbow installed? If so, the programmer was stopping the over boost code.
Sent from my iPhone using Tapatalk 2
Old Sep 18, 2013 | 08:19 PM
RoJazz13's Avatar
Where do I find the adjustable boost elbow? First Cummins sorry.
Old Sep 19, 2013 | 06:42 AM
Jbremount's Avatar
It's on the turbo. I not 100% sure about your year model truck, just throwing this info out. (still learning too!) Anyway, the adjustable elbow and programmer with boost fooler work together. The adjustable boost elbow will raise the turbo pressures higher than factory/stock levels and the programmer with boost fooler will keep the computer from throwing codes and defueling/bucking at higher than factory boost usually at higher speeds. That's how it works on my truck which is a 2004.0 The 2003-2004.0 still had a manual wastegate.
Adjustable Boost Elbow
http://www.bing.com/images/search?q=...F6&FORM=IQFRBA
http://www.dieseltruckresource.com/d...ow-t27695.html
Old Sep 30, 2013 | 08:34 PM
RoJazz13's Avatar
Looked at the turbo today. It looks like the adjustable elbow is on top. Doesn't look like one in pic probably because its old and dirty. I can't see wastegate on the side of the turbo. What does having the elbow mean?
sak240
Oct 1, 2015 04:07 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
Crews8r
Dec 21, 2014 07:35 AM
GreenDieselF
Oct 20, 2014 02:05 PM
