Vacuum pump oil leak
Old Sep 2, 2013 | 09:11 PM
Zach81smith's Avatar
Default Vacuum pump oil leak
I'm trying to find a seal kit for my vaccum pump because there is an oil leak coming from around the vaccum and ps pump. But I can only find a seal kit for 91.5 and up. Will that work on my 1990 or no. If not does anyone know where I can find one that will work?
Just looked at it a bit more and it seems to be leaking from the thing below the vacuum pump. I'm not sure what its called but its that round thing below it that says outlet. When I started the truck it kind of shot oil out of the little round cap right on the bottom. Not to sure what to think now?
Last edited by Zach81smith; Sep 2, 2013 at 09:11 PM. Reason: Automerged Doublepost
Old Sep 3, 2013 | 07:06 PM
tiremann9669's Avatar
Try Geno's garage or fixinrams.com
Old Sep 4, 2013 | 09:52 AM
cougar's Avatar
I got mine from Gould Gear and Electric (GOULD GEAR & ELECTRIC INC.). The kit plus the vane set was $93 in 2011. Seal kit p/n GG01 9195 3. Vane set p/n GG10/FV.
Old Sep 4, 2013 | 01:29 PM
Will that seal kit work on a non I/c kit?
Non I/c truck *
Last edited by Zach81smith; Sep 4, 2013 at 01:29 PM. Reason: Automerged Doublepost
Old Sep 4, 2013 | 04:23 PM
cougar's Avatar
No, the NIs use diaphragm pumps instead of a vain pump.
Old Sep 4, 2013 | 05:38 PM
So I'm stuck then cuz I can't find any rebuild kits for the diaphragm vaccum pump. Any suggestions on what I should do?
Old Sep 5, 2013 | 09:20 AM
cougar's Avatar
Shouldn't be hard to find seals and o-rings. You will just need to take it apart and measure it. If you need a quick turnaround, check the bone yards. You should be able to find 1.
Old Sep 5, 2013 | 11:00 AM
I'm gonna take it apart this weekend. Thanks for the help once again man.
southern dieselnorth zip
May 18, 2015 01:02 AM
Gomerpile79
Apr 9, 2015 03:45 PM
moneypitk5
Feb 12, 2015 11:01 AM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
