injector help
Old Aug 29, 2013 | 11:14 PM
diesel life's Avatar
Default injector help
ok guys its time for my next mod and im thinking some 150hp injectors or tips.. i have the built tranny ready to go in just waiting on this stocker to emplode...... so looking at my sig what injectors would you guys suggest???? and would you do the full injector or just the tips???? would prefer to run the stock turbo for about a year and then get an s300 or something similar. its a daily driver that tows our 17ft stratos 275v fishing boat and a 21ft deckover with quads or a load of logs. any info appreciated thanks
Old Aug 30, 2013 | 01:33 PM
jigabop's Avatar
complete injector. if you do just tips you will need to get the injectors pop tested afterwards. easier and less hassle to just get the whole thing already set up and ready to go.
7x.010 SAC injector from DFI would do nicely with the edge turned down to economy mode. believe me it will have more than enough power with those injectors on economy mode...much higher and you will send drive pressures through the roof on the turbo.
btw I would ditch the stock turbo if you have that junk hy35...
at least run an hx35w till you can afford a 62/71 or 63/68
Old Sep 3, 2013 | 12:00 AM
unfortunantly i do have the ole hy35 thanks for the input.. just one question: how much horse is a 7x0.10sac?? i looked em up and dfi has them pretty reasonable they also have a 63/68/.88 for not a bad price may just get it all togather
Old Sep 3, 2013 | 08:11 AM
jkidd's Avatar
you will definitely want a bigger turbo. the 63/68/.88 will be a laggy dog
Old Sep 3, 2013 | 11:59 AM
jigabop's Avatar
yeah, I would go for a 63/68/14cm^2 not a .88A/R (roughly a 16cm^)
63/68/14 with 7x.010 SAC would be a nice combo.
7x.010 = approx 150hp
Old Sep 4, 2013 | 12:38 AM
thanks jkidd, should be one in your box!!!!
thanks for your help, definantly be putting in the built tranny with that combo, sounds like a good power gain.
Last edited by diesel life; Sep 4, 2013 at 12:38 AM. Reason: Automerged Doublepost
