99 Sub 1500 acceleration issues
Old Aug 28, 2013 | 04:16 PM
DieselSuburbanSteve's Avatar
Default 99 Sub 1500 acceleration issues
Hey guys, my truck is idling good but as soon as it accelerates it blow black smoke and rpm's come up slow. I thought it was my leaky cross over pipe...changed it. vacuum pump was not sucking hard and knocking...changed it. Waste gate actuator operates and not has good press (can't move it by hand at idle). LP seems good. No rpm change when fuel bleeder open. Pumps out bleeder when open and ignition on (not running). Pmd changed a couple years ago and remote mounted only on top of manifold. Will scan codes later today when friend stops by. Do codes "lock" and I just need to clear them. Any advise on other things to check or things to look at with scanner. Will post codes when I read them. I'm sure this will help on whether it fuel or air. Thanks in advance
It is a F vin (no egr)
I'm getting a po236b code - turbo control. I cleared it and it has not come back. Could have been from leaking cross over pipe. Is it fair to say my soot trap may be plugged?
It seems to be getting worse (the last few short rides I've tried it). Thoughts?
Last edited by DieselSuburbanSteve; Aug 28, 2013 at 04:16 PM. Reason: Automerged Doublepost
Old Aug 29, 2013 | 12:29 AM
cviola2005's Avatar
Is your turbo working correctly? I think the turbo control code comes from the MAP sensor. Which could have been because the vacuum pump wasn't working. Could that have thrown it into limp mode?
If your soot trap was plugged, would be blowing black smoke like you are describing?
Have you checked or changed your air filter lately?
Hopefully this helps some.
Old Aug 30, 2013 | 06:32 AM
I split the exhaust at the flange and she runs great now. Sounds awesome but a trip to the exhaust shop and it will be all good. Thanks for the help
Old Aug 30, 2013 | 03:38 PM
cviola2005's Avatar
So the soot trap is plugged? I never would have guessed that, being that you had black smoke on acceleration. Glad you got it fixed.
Thanks for posting what you found to be wrong with it. May help someone in the future.
Old Aug 30, 2013 | 06:00 PM
I guess since the turbo isn't spooling up but delivering extra fuel she burns black. Put in a straight pipe in place of soot trap and good as gold
Old Sep 1, 2013 | 08:30 AM
cviola2005's Avatar
glad to hear you got it fixed.
dwmeehan
Jan 29, 2025 12:13 PM
Jun 8, 2015 11:10 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
Nov 25, 2014 10:30 AM
