Turbo question
Old Aug 27, 2013 | 02:00 AM
kerley's Avatar
Default Turbo question
Hey guy's I need some Info.
My Cummins just does not have the power that it use to have. I have been moving Hay and she just is not putting out. I never hear my Turbo spool and I am not getting very good mileage. I am pulling an eighteen ft. G/N with eleven rolls of tightly rolled hay.
How do you test your Turbo to find out if It's working properly?
Old Aug 27, 2013 | 11:36 AM
jigabop's Avatar
first off, do you have a fuel pressure gauge on there?
if not, get one asap...all 2nd gen 24v's should have a fuel pressure gauge whether they are stock or modified.
also when is the last time you changed the fuel filter?
checked for boost leaks?
Old Aug 27, 2013 | 02:27 PM
kerley's Avatar
I'm sorry, I should update my truck. Autometer fuel guage, Autometer oil pressure guage. Fass DDRP FP idle 27 Freeway speeds 23-24 wot 18-20, steering brace.
I might also add that each round bale averages 1100 lbs. So G/N weight and 12,100 lbs and burned 7.65 gal diesel for 98.7 miles might not be so bad? However I still cant hear the Turbo whine or feel any extra power loaded as described or empty without the G/N.
Old Aug 28, 2013 | 11:21 AM
jigabop's Avatar
check for boost leaks, and possibly need to clean the map sensor...
boost pressure gauge doesn't hurt to have either.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
