completely frustrated or am i just naive? help plz
I have a 2006 6.0 and it pops thru intake. I went and had it scanned top to bottom and compression tested and everything comes back perfect. The mechanic said he has heard the sound before but mine was just a bit louder than usual and I have nothing to worry about. Is he accurate....
Was bad guide. . . It ended up poor maintenance did it in. . What else does yours do? How often does it pop?
Does it seem to affect performance? Or just a nuisance noise?
Last edited by Adrenaline junkie; Aug 27, 2013 at 06:28 PM. Reason: Automerged Doublepost
always at idle and doesnt get anyfaster when driving and everything else is perfect
its a nusiance noise im wondering if i should put stock air filter back on
its a wop wop wop
i have studs egr delete coolant filter cat 1 elc coolant, powermax turbo with h&s tuner if that helps oh and afe intake
these things suck in a ton of air, you are just hearing it because the AFE intake, if you stop hearing that at idle then you will know your filter is real dirty. the huge paper filter that is stock muffles the sound.
