O/D Help!!
Old Aug 25, 2013 | 09:44 PM
NKY 1stGener's Avatar
Default O/D Help!!
Im wanting to wire my o/d to a floor headlight high low beam switch so i can control when it kicks in. Could anyone who has done this or something similiar give me some tips as to which wire goes to the actual solenoid on the tranny for o/d as well as how youve routed it. Any help would be greatly appreciated, Thanks!
Old Aug 26, 2013 | 11:42 AM
cougar's Avatar
There are 2 wires that run to the OD solenoid. A dark blue one which is power, and an orange/light green one which is ground. Both of which can be picked up on the 2 connectors at the rear of the engine. The wire you want to " redirect" is the orange/light green one. Cut it, run it to your switch and ground the other side of the switch. That will leave the ecm end disconnected.
Old Aug 26, 2013 | 06:34 PM
Ok thanks! Where did you ground yours too?
Old Aug 27, 2013 | 09:35 AM
cougar's Avatar
I retained my original switches using a circuit board to control a relay. I located the board under the dash and tied the ground in with others under there.
Here is my write up.
https://www.dieselbombers.com/1st-ge...-function.html
POWERSTROKEMANIAC
Nov 18, 2015 05:28 PM
Cutlass26
Mar 22, 2015 05:46 PM
