Clutches. Need pics and dimensions please
Old Aug 24, 2013 | 11:49 AM
cviola2005's Avatar
Default Clutches. Need pics and dimensions please
I am researching for a tranny swap and am in need of a few dimensions. Basically I am putting a T56 in my truck. I'm trying to find out if the T56 pressure plate will fit the diesel flywheel, by measure of a few dimensions requested below.
If you have spare parts or old replaced parts, they will do, if you don't mind helping me on my quest. Here are a few dimensions I need:
on the flywheel,
two opposing pressure plate bolt holes and any locator pins
the depth of the crank bolt hole area compared to the friction surface
and finally, the inner and outer friction surface diameters
on the friction disc,
inner and outer friction diameters
difference between the surface area and the metal that sticks out the most
on the pressure plate,
with a straight edge across the friction surface, the distance from it to the fingers.
It would also help to know the slave cylinder throw, if anyone knows or can measure.
Thanks in advance for any and all help. I have the money to buy the parts I need, but I don't want to waste money buying parts that wont work.
