The Ole Smoke issue.
Old Aug 23, 2013 | 12:03 AM
lockedwheels's Avatar
Default The Ole Smoke issue.
Welp I have been a lurker on here for a while, but I never joined. I'm bored as hell at work and figured I might as well go ahead and become a member finally. I have a 2006 with RCD egr delete, new oil cooler, replaced stc fitting, stock tuned, coolant filter, edge insight. My delta was kinda erratic, so thats when I did the egr delete. Well Its been like 600 miles and i am still getting a lot of white smoke. The week after I put it back together it threw two codes for cylinder contribution on even numbered cylinders, I chocked that up to having air in the lines. After that week it never threw a code again. Average diffrence between temps now is like 5 degrees. I have been monitoring my levels and I dont see a drop in coolant at all. My edge insight shows 47.5 volts at start up and 48 when running. I took it to the dealer and he did a contribution test on it and didnt see any irregularities. He said one injector could be functioning at 60% but if all the others are at 100% it hides the bad one.. Didnt make sense to me but who knows. I am getting an average of like 12.4 mpg which seems kinda low to me. I would swear its my head gaskets but im not losing coolant. Only other thing I notice is while I am accelerating at around 2500 rpms I notice the needle start to flutter and I hear the exhaust waver (almost stutter). The smoke is white with maybe a blue tint, it kinda hangs around for a few seconds, and doesnt dissapear right away. So is the tech right ?? am I just loosing an injector or two slowly ??? I'll buy a case of beer to whoever can troubleshoot this.
Old Aug 24, 2013 | 07:42 PM
Adrenaline junkie's Avatar
How is your oil maintenance? You can try Rotella t-5 synthetic 5w-40 or similar with archoil or rev x to relieve stiction issue. . There is hot shot secret in tractor supply stores too . . Seems to clear up stiction for some. . . Just a place to start . .
Old Aug 26, 2013 | 02:05 AM
I am running Valvoline Extreme Diesel fully synthetic. I added two bottles of RevX when i replaced oil cooler and did all the other work.
Screw it.. Studding the heads performance injectors and a tuner. Goodbye bank account
Last edited by lockedwheels; Aug 26, 2013 at 02:05 AM. Reason: Automerged Doublepost
Old Aug 26, 2013 | 06:13 AM
Sounds like hello fun tho!
Old Aug 29, 2013 | 11:11 AM
Smokey Freedom's Avatar
Whats your fuel pressure? Assuming not losing oil right?
Old Aug 30, 2013 | 05:18 AM
I am not sure of my fuel pressure. I am not losing oil. I said screw it and bought studs for it and injectors.. Hopefully gettining it done this weekend. WIll keep you posted.
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
Rustbucket
Sep 19, 2015 09:58 AM
sandlappa
Aug 23, 2015 09:20 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
