rpm moving going down the road
Old Aug 21, 2013 | 08:30 PM
Southerninjection's Avatar
Default rpm moving going down the road
the rpm will move about 200 rpm back and forth only when you are at a steady speed, if you accelerate or let off the pedal it doesnt not do this.
wonder what is going on thanks for the input
Old Aug 22, 2013 | 06:52 AM
RAW's Avatar
RAW
Sounds like the torque converter (TC) is locking and unlocking. When it does this surging, try gently pressing on the brake while you still have a foot on the throttle. When the brake light switch is tripped, the TC should unlock. While you foot is on the brake, the ROM will stop surging if it is a TC lock up problem.
Old Aug 22, 2013 | 07:37 AM
illinoisfox's Avatar
I would suspect the converter is unlocking then relocking.
If so, it is noise in the computer input signal. Clean battery posts, wrap rarger brown wire from alt. area to passenger battery with aluminum foil! Then add a noise filter to the computer input signal. you can get them on E-bay.
Old Aug 23, 2013 | 10:36 PM
codyawise's Avatar
I had that issue and got a apps noise isolator and been fine since
InheritedDiesel
Apr 12, 2015 04:35 AM
Apr 3, 2015 11:50 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
dutchsupreme
Dec 18, 2014 01:44 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
