8 mpg pulling my 28 ft 5th wheel
Old Aug 21, 2013 | 06:41 PM
jt79's Avatar
Default 8 mpg pulling my 28 ft 5th wheel
I have a 95 chevy 1500 6.5. good power till about 60. poor fuel millage think the timing could be off would this effect this? the inj timing at Idle is 6.5-6.9
Old Sep 15, 2013 | 10:51 PM
fommy100's Avatar
Look at your GVWR load on your door ie. 5630 lbs for example. most half ton trucks have 3.08 gears fitted which are meant to give you good fuel economy, the 3/4 ton and 1 ton trucks go upto 7200lbs 8200lbs etc different gearing load capacity's. Go too a 5th wheel site.... and they usually have graphs that will let you see in a instant what load capacity you are okay with with a 1/2 ton truck. I suspect the fuel economy issue will be to do with your rear axle.
Old Sep 16, 2013 | 06:05 AM
Mayhem's Avatar
X2 My 3/4 ton is very low geared like top end 80ish but I can idle with a 27' goose neck with 7 rows of hay all day long across any field oh and with the A/C on Max Oh and yes I have the NV4500
Old Sep 16, 2013 | 12:01 PM
racer55's Avatar
Another factor for the low geared trucks at highway speeds is that the stock turbo lays down above 2400 rpm so to save the engine and fuel you sometimes can't travel over 60 mph no matter the posted limit.
The 1/2 ton is likely just plain overloaded with your trailer unless it is an alumilite with empty tanks.
Remember these are light duty diesels built for economy not medium duty work trucks like the Cummins and IH ford uses,the worst cummins and powerstroke out muscle or trucks and only go up from, there.
The little 6.5 is only 180 hp (134 kW) @ 3,400 rpm / 360 lb·ft (488 N·m) @ 1,700 rpm
there was a special built marine engine that exceeded these specs but is not offered for trucks.
Cummins:
5.9L Cummins 24v Specs
Ford/IH 7.3:
Ford Power Stroke engine - Wikipedia, the free encyclopedia
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
carid
Group Buy
Apr 8, 2015 06:11 AM
6.5dieselman
Feb 26, 2015 04:45 PM
Jan 14, 2015 03:40 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
