2004 f250 ECM voltage question
Old Aug 19, 2013 | 06:29 PM
DrivenMad's Avatar
Smile 2004 f250 ECM voltage question
I am getting lower voltage readings at teh ecm compaired to the batteries. Is this normal??
Low batterys = 10.5 volts at battery / 9 volts at ecm
charged overnight batteries = 13 volts / 10 .2 at ecm
Is this normal?? Troubleshooting a no start, realized no power to fuel pump, or even the inertia switch for that matter and reference voltage for sensors is showing .1 volts. I dont have a high end code reader, just a bluetooth one. no codes from that. Im still trying to find a detailed wire color diagram for this truck. I have the coffee table bible one ,but it does not show wire colors.
Any ideas or experiences??
Thanks for the help
Old Aug 20, 2013 | 03:31 AM
HeavyAssault's Avatar
How are you reading voltage at the ECM???
Old Aug 20, 2013 | 04:06 AM
DrivenMad's Avatar
Default Voltage at ecm
Well since i cannot get the bluetooth reader to talk. i unplugged the center connector on ecm and used a volt meter on the second pin from the top right as a reference. (it was the only pin that had more than 1.5 volts on it I could not find a pinout / wiring diagram for the ecm.
Old Aug 31, 2013 | 12:42 PM
DrivenMad's Avatar
Woot :0 I found a chaffed wire in the bundle behind the fuse box!!! truck now talks to ecm and getting fuel still no start but we are closer !!!
ajkx10
Apr 22, 2015 04:49 PM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
yhatzee89
For Sale
Mar 1, 2015 09:03 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
tumble72
9
Nov 10, 2014 09:06 PM
