doing a motor swap need a little insight plz
Old Aug 17, 2013 | 09:36 PM
bergs's Avatar
Question doing a motor swap need a little insight plz
98 Chevy 6.5 turbo blew found a 94 gmc 6.5 turbo wondering if its all the same or if I have some improvising to do with wiring and or computer
Old Aug 17, 2013 | 11:39 PM
TheyCallMeCountry's Avatar
94 motor is OBD 1
98 is OBD 2
Swap things the other direction-make the 94 like the 98 was.
Also check the # on the 94 IP-if it ends in 5068, you are going to have to swap the 98 IP too.
Take everything from the 98 an put it on the 94 block. Electronics, ecu, etc...
To bad you didn't take the simply route an find a 12 valve and a nv4500 trans and transfercase to swap into it.
Old Aug 18, 2013 | 09:06 AM
bergs's Avatar
yeah that would be good but I don't have a lot of time to do this motor swap unfortunaly thanks for the reply I will defiantly be changing all that then thanks
Old Aug 22, 2013 | 12:19 AM
cviola2005's Avatar
like he said, keep everything that is 98.
itvinny
Jun 19, 2015 09:26 PM
itvinny
Jun 19, 2015 09:21 PM
Dr67
Apr 30, 2015 12:36 PM
negadiesel
Feb 28, 2015 06:34 PM
