Need help priming
Old Aug 17, 2013 | 05:20 PM
codyawise's Avatar
Default Need help priming
So just changed my fuel filter and can't get my truck primed to where it'll start. How can I get it primed enough to start? I've even dumped fuel in filter in hopes of it startin but just cranks. I need help asap
Old Aug 17, 2013 | 05:29 PM
Cornfed 1020's Avatar
did you crack the lines going to the injectors and bump the ignition. also see if your lift pump is working as well
sorry crack the number 3 injector fuel line bump the ignition and then once you get fuel tighten it down and it should start
Last edited by Cornfed 1020; Aug 17, 2013 at 05:29 PM. Reason: Automerged Doublepost
Old Aug 17, 2013 | 06:07 PM
1999stroker's Avatar
I cracked the line going to the IP and bumped the Starter then re connected and sge fired right up.
Old Aug 20, 2013 | 11:51 PM
340DartMan's Avatar
Maybe for future reference: I drain and save the fuel from the filter housing. After reinstalling the filter housing with the new filter, I pour the fuel back into the top through one of the ports. Never had a problem starting my truck when changing the filter this way.
Sent from my GT-P5113 using Tapatalk 4
Chadpando
Jun 25, 2015 04:00 AM
