NV5600 clunks
Old Aug 16, 2013 | 04:11 PM
6.2Lturbo's Avatar
Default NV5600 clunks
When changing gears it makes a clunk if I shift a little slow or with out the clutch, but when you push it and shift fast it doesn't make a noise. Looking for what it could be before it get worse and possible breaks?
Old Aug 25, 2013 | 05:32 AM
Jbremount's Avatar
I would like to know the answer to thisl! Mine does this also! I taken my truck to several transmission shops and they all said they did not know without tearing it down which one may as well replace the clutch. I suspect the bearing on the flywheel is not adequate. When I replace the clutch, I will fix that.
Old Aug 28, 2013 | 12:40 PM
6.2Lturbo's Avatar
I checked it out this week and found I had a u-joint badly worn. Changed it out and the noise has now gone. You might want to check that
boostkid
Jun 3, 2015 11:17 AM
dpgcummins12v
12
Apr 20, 2015 10:24 PM
SixSpeed
Jan 11, 2015 01:41 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
