twin turbo setup
Old Aug 14, 2013 | 10:27 AM
bulletproof6.0's Avatar
Default twin turbo setup
can you use a turbo from a 7.3 to do a twin turbo set on a 6.0?
Old Aug 14, 2013 | 06:48 PM
HeavyAssault's Avatar
I'm not that informed on setups for twins. I do know you need a smaller unit pushing the bigger unit. So if the 7.3 is smaller it could work. I currently don't know of or have ever read of a non-vgt turbo set up too feed a VGT turbo.
I do think that is the purpose of the VGT. To act like a different turbo (smaller/larger) depending on engine demand.
Old Aug 14, 2013 | 07:59 PM
Coastal350's Avatar
Get two stock 6.0 turbos
Old Aug 14, 2013 | 09:08 PM
is there a diagram for the setup using the two 6.0 turbos?
Old Aug 19, 2013 | 05:50 AM
Most twin setups are a custom design so to speak. There are some shops that will sell a kit but it's best to give them the keys so you can just write a check at the end.
Old Aug 19, 2013 | 01:53 PM
bustedknuckles's Avatar
When they do a two stock turbo setup, do they run them in parallel or series?
Do they feed one bank of cylinders with one turbo and the other bank with the 2nd turbo, or do they feed one turbo into the other turbo?
Old Aug 19, 2013 | 03:57 PM
Twins feed one another. Use a smaller turbo to push the larger turbo. Two stock 6.0 turbos are not used for a twin turbo setup.
http://www.alligatorperformance.com/...es-p-6348.html
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
